440 CID IH HP????
Eric
03-20-2004 17:44:27
I have a Farmall M with 440 CID. I have 110 hp presently with a good 450 gas head, decent cam etc.
My compression is 240 per cyl. and I use 118 fuel. How much HP can I get out of it and what should I do to get there. If you have a similar set up I'd like to hear from you.
Mark
03-21-2004 08:41:46
 Re: 440 CID IH HP???? in reply to Eric, 03-20-2004 17:44:27
Eric I do the wrenching on a Farmall motor your size and last year we were getting 160+hp.This year with a few more mod's we are hoping for over 200 hp.
ChadS
03-21-2004 09:05:09
 Re: Re: 440 CID IH HP???? in reply to Mark, 03-21-2004 08:41:46
I belive that is possible. good luck! Chad
a puller
03-20-2004 20:52:54
I'm not a IH engine builder..but I believe you should check and see what the lowest octane fuel you can run in it is..it could gain you a little....1-3hp...I believe you should be able to run 110. Can I ask how much the 118 is though..I have a JD A that pings on 110!!...lol..
