730D tire size??
Jonathan Dickey
03-21-2004 03:57:17
I just started the restoration of a 1959 730 Diesel. When completed I would like to take it to some of the local pulls here in southwestern PA. I would only be pulling stock classes and am wondering what size tire would be the best to use. I am thinking about 14.9-38 Firestone because of the larger plate area than a 15.5. 16.9's would be nice but I think they'd be too tall for the fenders. Radials aren't out of the question either. Any input would be greatly appreciated. Thanks
John
03-24-2004 20:50:26
 Re: 730D tire size?? in reply to Jonathan Dickey , 03-21-2004 03:57:17
I run 16.9's on my 720 only because I am too sorry to round up a set of wheels and mount some 18.4's. If you plan to pull bigger is better. The 16.9's are a good compromise and look good on the tractor. Especially if it is a wide front with 9.5 x 15 low profiles on the front. Everyone has their own opinion but a 730 with 15.5's looks ODD. Way too small! The 18.4's will clear the fenders, besides as someone else mentioned, they are adjustable.
JL
03-21-2004 17:48:27
I pull a 730 diesel too. It did real good with the stock 15.5's on it (and I've never seen one with a smaller size) but we needed more traction on some tracks and ended up putting on a pair of 18.4's that I got for free. But, my tractor had an optional transmission and didnt have the creeper gear, so I had to install it since the bigger tires are a little faster.
If you have the flat top fenders they adjust for different sizes. I have them on now even with the 18.4's on. I think my fenders are off a 4020, but I believe they are the same except for an extra hand-hold.
I pull in Mercersburg PA. and McConnelsburg (sp?) every now and then. Is this around you?
Jonathan Dickey
03-22-2004 06:49:47
 Re: Re: 730D tire size?? in reply to JL, 03-21-2004 17:48:27
Im from Somerset county. There are monthly pulls at New Centerville (Farmers and Threshermans Jubilee grounds) and also in Listie. I also pull at the Somerset county Fair in Meyersdale. I live in Berlin and am still waiting to hear if we're getting a pulling track put in somewhere to replace the one the school district paved over. I've heard a little bit about a pull in Bull Skin??? I think its in Westmoreland county but haven't been there but I'd like to check it out.
Ron
03-21-2004 06:37:01
Most antique pulls will not let you pull radials.
farmall kid in pa
03-21-2004 14:26:29
 Re: Re: 730D tire size?? in reply to Ron, 03-21-2004 06:37:01
jonathan i am also from southwestern pa i am located in beaver county. where r u located. maybe u could come up to some ob the BKATEA(Big Knob Antique Tractor and Equipment Association) pulls located in rochester Pa
