I hope it will be ok?
Jack
03-28-2001 09:10:02
I took my G JD head to the local machine shop and told them to shave .125 off and when I went to get it they took off .150 instead.It was more than I thought it would be just looking at it.Will it hurt anything having that much off?Will I have to shorten the push rods?They took it all the way down to the eyebrow on the intake valve.It is not the flat head.Thanks.
Will
03-29-2001 16:26:13
 Re: I hope it will be ok? in reply to Jack, 03-28-2001 09:10:02
This is somthing to tell the shop guys next time is to just take off enough to true up all the sealing areas that the gaskets are on. Not unless you are making a puller. Alot of guys will do a head that way for more power. You might have to run good premium gas in it if you work it hard so it dont ping. Your push rods will be ok there is enough adjustment on the rockers. If not let us know and we will help. Will
Jack
03-30-2001 08:17:00
 Re: Re: I hope it will be ok? in reply to Will, 03-29-2001 16:26:13
Thanks Will I put it together last night.
