D17 for pull?
T Snyder
11-22-2001 18:08:11
Would a 1958 D17 make a competitive puller? What would be it's toughest competition be, generally speaking, assuming stock for stock?
I have never noticed a D17 pulling. Why would that be? Too new to be allowed or non-competitive? There are plenty of WC's
Can someone enlighten me?
Kraig
11-26-2001 10:29:19
 Re: D17 for pull? in reply to T Snyder, 11-22-2001 18:08:11
I would think the D17 is too heavy for the power it has. You can build a WC engine to have the same power (or more) than a D17 with much less weight. If you want to run the heavier classes, use the souped up WC with more weights.
Mark
11-26-2001 16:49:54
 Re: Re: D17 for pull? in reply to Kraig, 11-26-2001 10:29:19
WC make good pullers I pull one from 3000 to 5000 but have a hard time keeping the front end on the ground in the 4500 & 5000 even with 400lb on front
any ideas.
Mark
11-26-2001 12:46:54
I pull a '58 D-17 in the classic division 3 and 4.I can get it in 4500 lb. to 8500 lb. classes.Normally I pull 4500, 5500, and 6500 lb.The tractor is competitive with placings in local pulls, and a third place pull at the Iowa State Fair in 2000-6500 open.The tractor has a hi and low in each gear-double that of a WD.Whatever you decide to do,you will have alot of fun!Hope this helps,Mark.
Kraig
11-27-2001 10:43:32
 Re: Re: Re: D17 for pull? in reply to Mark, 11-26-2001 12:46:54
Maybe a desiel D-17 with a turbocharger (same as D-19 engine) would be fun in open classes. I love the black smoke :^)
