HEAD GASKET SEALANT
DON C
03-25-2004 12:10:21
JUST HAD HEAD MILLED WHAT IS THE BEST WAY TO SEAL HEAD GASKET SOME SAY COPPER SPRAY OTHERS SAY HIGHTACK WICH WILL HOLD UP BETTER THANKS IN ADVANCE DON
ChadS
03-25-2004 12:17:10
 Re: HEAD GASKET SEALANT in reply to DON C , 03-25-2004 12:10:21
It depends, For most applications, a copper coat will do just fine on stock, or copper head gaskets. The best stuff in my book is made by Gasket Works INC, called GK-5. It is more forgiving than coppercoat. On copper head gaskets, and sleeved engines, there is a problem, the sleeve standout holds up the gasket around the bores and due to the standout, it does not seal the water from the oil. coppercoat will not seal this when this happens, the GK-5 will, it is designed to fill in more of the inperfections, or where you need to have a better sealer to hold. go to www.headgasket.com for more info on sealers, and Gasket Works products. Hope this helps, Chad
Shutt30
03-25-2004 17:27:25
 Re: Re: HEAD GASKET SEALANT in reply to ChadS, 03-25-2004 12:17:10
Can you get this stuff at your local auto parts store?
DON C
03-25-2004 12:23:53
THANKS FOR THE GOOD ADVICE AS USUAL KEEP UP THE GOOD WORK CHAD
DON C
03-25-2004 12:30:30
 Re: Re: Re: HEAD GASKET SEALANT in reply to DON C , 03-25-2004 12:23:53
THANKS FOR THE GOOD ADVICE CHAD
