Compression conversion question
Big Casey
03-29-2004 22:03:35
I have a puller that tests at 220 psi compresson. Is that equivalent to 11 to 1? I'm a little confused on that conversion. Can someone please tell me? Thanks.
Ohio M Puller
03-30-2004 07:38:53
 Re: Compression conversion question in reply to Big Casey, 03-29-2004 22:03:35
According to the equation I have for conversion I am coming up with 9.35 to 1 on your ratio.
Ohio M Puller
Compression Conversions
R=((P+14.7)/14.7)^(1/24)
P=(14.7*R^1.24)-14.7
Hope this may help.
phil
03-31-2004 08:52:23
 Re: Re: Compression conversion question in reply to Ohio M Puller, 03-30-2004 07:38:53
Ohio M, I think you meant R=((P+14.7)/14.7)^(1.24), not R=((P+14.7)/14.7)^(1/24)
hunter
03-30-2004 12:41:52
check out you formula...it does not work!
CASEPOWER
03-30-2004 06:54:47
I have a chart that converts it, but it was printed in the 30's when engineers were afraid of valve overlap. I would say it was accurate for it's time, but not for anything to much new then when it was printed. Going by this chart you would have 9.0 to 1 at 221.4 psi. Best way to tell the ratio is to pull the head and check the CC's and do the math.
farmall
03-30-2004 06:27:08
There are to many variables (like cam timing) to be able to convert C/R to actual PSI. I found a web site that may be of interest. WWW. compression ratio computation.com This site calculates compression ratio for different mechanical engine parameters. Hope this helps Farmall
Ron
03-29-2004 23:55:22
According to the 2-Cylinder Magazine... the 620 JD ( LP) has a compression ratio of 8.1:1, and the compression pressure calls for 216-237 lbs pressure...at Rated RPM, but only 185 lbs with the starter.. Sounds like you may be a Long way from 11:1...
FULLPULLER#1
03-30-2004 12:12:00
 Re: Re: Compression conversion question in reply to Ron, 03-29-2004 23:55:22
BUT,Ron,thats John Deer you can't use John Deer to compare anything with,cause that's an inferior brand of tractor,,,Case in point,,,King of The Hill in Mississippi,,,,, Hay farmall what do ya say about that?.
farmall
03-30-2004 17:26:49
 Re: Re: Re: Compression conversion question in reply to FULLPULLER#1, 03-30-2004 12:12:00
Well said!
buickanddeere
03-30-2004 20:06:21
 Re: Re: Re: Re: Compression conversion question in reply to farmall, 03-30-2004 17:26:49
That's the same Case and Farmall that went broke while Deere stayed in business?
WILDMAN
03-31-2004 04:44:24
 Re: Re: Re: Re: Re: Compression conversion questio in reply to buickanddeere, 03-30-2004 20:06:21
THATS AN OLD STORY.
Flogger
03-31-2004 05:07:25
 Re: Re: Re: Re: Re: Re: Compression conversion que in reply to WILDMAN, 03-31-2004 04:44:24
Auctually farmall never went broke or out of business. The IHC company is very much alive under the Navistar name. They did sell the ag equipment line to Case back in the 80s, and the industrial line to Dresser, but I think it was more an issue of economics than quality of the product.
But Still
03-31-2004 23:02:01
 Re: Re: Re: Re: Re: Re: Re: Compression conversion in reply to Flogger, 03-31-2004 05:07:25
But still face it. Case and IH farm equiptment
no longer exist!! Unless you consider them
to be blue. If they were so good they would still
be here economics or not.
Flogger
04-01-2004 14:27:16
 Re: Re: Re: Re: Re: Re: Re: Re: Compression conver in reply to But Still, 03-31-2004 23:02:01
Well seems to me quite a few "inferior" I-Hs, Allis Chalmers, Olivers, and Molines are still with us. I'll bet you've had your A$$ spanked by all of them too.
