Help a new puller
farmall h
11-26-2001 19:14:12
I have an farmall h and want to build it to pull open class. Is this possable? If so what can i do we have to use the factory block.
Thank You
BigRed
12-05-2001 18:38:20
 Re: help a new puller in reply to farmall h, 11-26-2001 19:14:12
You can do o.k. with an H. Mine is a 1947. overhauled with super H pistons 13.5x38 new tiresOne set rear wheel wts. and 240# on rear drawbar. I pull 4600# stock class and won 3rd. in my class for the yr. Tractor pulls good as long as it has some slipage but on hard track gets to good a bite and powers out. You will always be pulling aginst tractors with more H. P.in your wt. class, good luck.
ff316
11-28-2001 14:53:11
I'm no expert but I think the best thing you could do is use your H for hay rides and get an M to pull. It would probably cost quite a bit to make your H competitive with a stock M, and M's are pretty plentiful. Good luck with whatever you do. Fireman
paul
11-27-2001 04:07:48
call Lemons At 765-938-1808
