Tires
Will
03-28-2001 15:44:43
I was thinking of taken my 14.9 by 38 off and putting on 15.5 by 38 to try and get some more power. The 14.9 tires work good but i think by doing this it will be like having half of gear. I/m thinking with the change in tires when i'm in 2 gear it will be like 1 an ahalf gear? What do you guys think. Thanks Will
Gary
03-29-2001 11:30:03
 Re: Tires in reply to Will, 03-28-2001 15:44:43
Sidewall height varies from one brand to another
and doesn't necessarily vary the same.Measure the
circumfrance [sp?] of each tire then divide one
by the other,this will give you the percentage of
change of one to another.
CWS
03-28-2001 19:05:13
15.5's are 4-5 inches shorter than 14.9's. This will reduce ground speed 6-8% in each gear.
Jerry B
03-28-2001 17:04:51
Will,
I dunno 'bout that.
The 15.5's are taller than the 14.9's They would produce a little more surface speed at any given rpm over the 14.9's. Instead of slowing down, you might be going faster. And it may not be anywhere near 1/2 a gear either.
imho
TGW
03-30-2001 18:53:19
 Re: Re: Tires in reply to Jerry B, 03-28-2001 17:04:51
The 15.5's may be a higher number but are definetly shorter, min. of 3"
G Taylor 15.5 are shorter than 14.9's
03-29-2001 00:48:27
A set of Firestone 14.9x38's on 14" rims vs 15.5x38's on 14" rims. The 14.9's are 3% faster with 6% more surface contact area.
Will
03-29-2001 16:05:08
 Re: Re: Re: Tires in reply to G Taylor 15.5 are shorter than 14.9's, 03-29-2001 00:48:27
I think i'll leave the 14.9s on if i'm going to have more contact on the track with them. I guy can never have enough traction. Thanks for the info guys.Will
burns
03-29-2001 11:39:14
Before mounting new 15.5x38 Firestone F&R on our Farmall 400, I stood them beside my used 14.9x38 Armstrongs mounted on my JD G. I would guess that there is minimal wear on my 14.9's. Both are mounted on 14" rims and both have the same amount of air. The crown of the 15.5's was definitely higher than the 14.9's but the meat of the tires were fairly equal. Granted I have one set on a tractor and the other just sitting there and I have two different brands. Far from a scientific method of measuring.
Slo
03-28-2001 17:18:30
15.5's are wider, but definitely shorter. They will slow down your wheel speed.
Jerry B
03-28-2001 18:05:28
 Re: Re: Re: Tires in reply to Slo, 03-28-2001 17:18:30
ok..I learnt sumpthin'.
Thanks. :)
To be honest my 15.5's looked to be about the same height as my 14.5's. I just took it for granted that perhaps they were mounted on different width wheels and that made the difference.
missery
03-28-2001 17:04:04
would help know what kind of tractor you have.i pull antique stock.the tires on my tractors are the size nebraska's tested on.the biggest thing i have found,in the area i pull in is to stay with 4 ply tires.my dad pulls an oliver 770 w/ 13.6,38's on 12 inch rims. i pull an oliver 66 w/11.2 38's 4 ply's. my 880 is on 15.5 38's.
