H carb question
DavidE
04-06-2004 18:18:21
I am new to your discussion board, need some information about carb venturi. I'm currently running a M carb on my H it seems to run too rich at mid throttle. I was wondering if there was a smaller venturi and different jet available. Thanks for any help.
ChadS
04-07-2004 07:18:49
 Re: H carb question in reply to DavidE, 04-06-2004 18:18:21
there is only 1 venturi smaller than the M, it is the super H-350. what is happening is that the vacuum is too low to run the M venturi, causing a fuel puddling effect in the ports, and flooding the cyl. change the venturi, and try to adjust it then, you should be able to dial in the carb then. if not, go to a better grade fuel. Chad
