Diesel air cut-offs
88
12-03-2001 04:12:27
Starting to expand my area fo pulling and will be required this next season to have safety swithches. Two of my tractors are diesels. Does any one have info on a neat not necessarily easy but functional way of air cut offs.
Am fairly mecahnically inclined, but certainly no professional.
Thanks in advance for all info.
Smith Pulling Team
Jerry B
12-03-2001 06:43:06
 Re: Diesel air cut-offs in reply to 88, 12-03-2001 04:12:27
I saw an air cutoff that was so simple. It used a rain cap with a gasket around the sealing surface and was held open by a pin. The pin was attached to a cable that ran back to the rear of the tractor where a loop was made to attach it to the sled. Pull the cable and the pin would slide out and the rain cap will come down.
Of course this setup required that the air intake be in a verticle position. If you spring loaded the setup it should function in any position.
If you use this method I would drill an extra hole that would allow you to pin the cap in the closed position as well.
88
12-03-2001 07:09:25
 Re: Re: Diesel air cut-offs in reply to Jerry B, 12-03-2001 06:43:06
Thank you for this info. Do you have any suggestions for an air cleaner using the system you described.
Smith Pulling Team
Masseypuller
12-03-2001 13:33:18
 Re: Re: Re: Diesel air cut-offs in reply to 88, 12-03-2001 07:09:25
"88" -
What I have seen in that case, is people using large (13 or 14 inch diameter) round air filters stacked 3 high and then mounting the shut-off (as Jerry described) inside that. That should provide plenty of air filtration area and volume to fit that shut-off inside!
Regards,
Masseypuller
bobby
12-03-2001 07:37:02
Guys around are area that have diesels that have to have kill switches are getting electronic solinoids and mounting them under the hood then running the fuel supply line through it. and then when you pull the kill switch then it shuts the fuel off.
Troy
12-03-2001 10:50:11
 Re: Re: Re: Re: Diesel air cut-offs in reply to bobby, 12-03-2001 07:37:02
Would work good until you take out a turbo seal and start running on pure oil.
Jerry B
12-03-2001 16:37:42
 Re: Re: Re: Re: Re: Diesel air cut-offs in reply to Troy, 12-03-2001 10:50:11
And a few hard shut downs will take out a seal real quick too.
Tyler
12-03-2001 18:12:23
 Re: Re: Re: Re: Re: Re: Diesel air cut-offs in reply to Jerry B, 12-03-2001 16:37:42
We have to have a three way valve(must be able to operate from the seat)in the line so that we can return the fuel to the tank should somthing happen. We just run a choke cable to it, pull the choke cable and it returns all fuel to the tank. In addition we must have an air shut off that is operable from the seat and as the kill switch.
