Flat top 301 pistons
Fantasy 560
04-23-2004 19:41:59
Does anyone know where I can get some flat top pistons for my farmall 301 engine? Any help is appreciated. Thank you
fergfarm
04-24-2004 01:30:48
 Re: Flat top 301 pistons in reply to Fantasy 560, 04-23-2004 19:41:59
try NAPA if its stock.Why do you want flat tops.Any of the piston makers will make what you want.ROSS,ARIES,J&E etc.
ChadS
04-24-2004 07:59:52
 Re: Re: Flat top 301 pistons in reply to fergfarm, 04-24-2004 01:30:48
Yep, NAPA would be a good source, get them for the truck 301, then you will get what you are looking for. He may be using a truck head, so that may be the reason for needing flat top pistons, Just a guess LOL!! ChadS
Fantasy 560
04-24-2004 15:50:59
 Re: Re: Re: Flat top 301 pistons in reply to ChadS, 04-24-2004 07:59:52
THANK YOU CHADS I AM USING A TRUCK HEAD.
CURTIS
ChadS
04-24-2004 15:56:43
 Re: Re: Re: Re: Flat top 301 pistons in reply to Fantasy 560, 04-24-2004 15:50:59
The truck head is good for building compression over a tractor head, you can bore em, and stroke em all you want, just keep the piston .010 min below the deck of the block for clearence. and will have more compression than the tractor heads. valve train may be different than the tractors too, have not checked to be exact, but the truck heads have a straight up and down valve, where the tractors are angled. Chad
