Farmall H rod journal size
Jim
04-25-2004 16:41:30
I am replacing the sleeves and pistons in my H farm tractor. Are the rod journals 2.25 inches? Mine are 2.23 to 2.21 inches. What is the tolerance for standard replacement rod bearings? I am not removing the crank and therefore will not be turning the crank.
farmall
04-26-2004 08:00:51
 Re: Farmall H rod journal size in reply to Jim, 04-25-2004 16:41:30
With that much variance on the rod journals you will be removing the crank if you want it to last at all.
