EXPLOSION @ Dickson????
Cody
05-09-2004 19:00:04
I heared that here was a massive relese of energy from the Under Pressure 88? I guess the ladies are right, bigger isn't always better.
ONE BAD OLLIE
05-11-2004 18:38:13
 Re: EXPLOSION @ Dickson???? in reply to Cody, 05-09-2004 19:00:04
with 150+ hooks i think something has to break sooner or later! funny thing is, i understand at 3000rpm he was kicking the 5000 - 6000 rpm tractors.seems to me Randy Head is THE MAN TO BEAT!!! and yes UNDER PRESSURE will be back on the track, so do your homework.
ChadS
05-10-2004 05:34:15
Did they also have the 460 they built down there? Sorry to hear about it blowing up. hope it is not serious! Chad
Hogan
05-09-2004 19:53:29
Is that Greg Tilley's old tractor, the one that's in the Hook in the Midwest wheels ad??
Puller
05-09-2004 20:10:12
 Re: Re: EXPLOSION @ Dickson???? in reply to Hogan, 05-09-2004 19:53:29
Yes that is the one.
Lou
05-10-2004 05:24:38
 Re: Re: Re: EXPLOSION @ Dickson???? in reply to Puller, 05-09-2004 20:10:12
Wasn't that billet crank,cam,rods,etc? What happened?
TN Thunder
05-10-2004 07:56:02
 Re: Re: Re: Re: EXPLOSION @ Dickson???? in reply to Lou, 05-10-2004 05:24:38
I saw that one pop! It was a pretty catostrophic explosion. It looked like a super stocker blowing apart! It looked like it had a couple of large holes on the carb side of the block. It totaled the engine, He was just worried about the crank. The force of the explosion blew the side panel up! The 460 wasn't that impressive, the 88 beat it in the first class, but it was still running at the end of the day.
Timmy
05-10-2004 11:29:29
 Re: Re: Re: Re: Re: EXPLOSION @ Dickson???? in reply to TN Thunder, 05-10-2004 07:56:02
The times I've seen it, especially idling around, it always sounds like its not running quite right (always sputtering), must have gotten the TimC tune job!
Red Rock
05-12-2004 14:03:13
 Re: Re: Re: Re: Re: Re: EXPLOSION @ Dickson???? in reply to Timmy, 05-10-2004 11:29:29
I'm really going to miss that sputtering. If I can get my tractor to sputter like the Oliver and pull in 5th gear like the Oliver I'll be one happy camper.
Cody
05-10-2004 11:54:13
I was told that it looked like it had aluminum rods in it. I was also told that it broke the 1 and 6 rod. It had a cast cam in it, because pieces of it were laying on the ground. I hate that it happened, but it is a very costly reality check for anyone who has a maxed out engine of any brand.
Crossville
05-10-2004 20:01:10
 Re: Re: Re: Re: Re: Re: Re: EXPLOSION @ Dickson??? in reply to Cody, 05-10-2004 11:54:13
hey cody, there was a red outlaw tractor in crossville last weekend that left a rod laying on the track.
Timmy
05-10-2004 16:36:45
I'm sure that it didn't have aluminum rods in it when it was originally built so unless TimC changed them out, they should have been billet rods. Sounds like it needs to get back to Duke and away from TimC!
North of 8 Rebel
05-10-2004 16:17:59
There you have it folks, another big stroker piece of garbage!! It blew apart, with limited rpms, geeze, I thought only high rpm motors blew apart everyone!! Funny, never seen any of the 5000 and 6000 rpm short stroke engines around here blow like that ever!!!
Cody
05-10-2004 20:57:11
 Re: Re: Re: Re: Re: Re: Re: Re: EXPLOSION @ Dickso in reply to North of 8 Rebel, 05-10-2004 16:17:59
I never had any trouble out of the high rpm engine I ran either except for spinning a rod bearing once. Like I said, I hate to see anyone's stuff tear up, but it is just a fact that things streched to the limits, are going to have to give sooner or later. Whose red tractor left a rod in Crossville?
farmall
05-11-2004 15:10:56
 Re: Re: Re: Re: Re: Re: Re: Re: Re: EXPLOSION @ Di in reply to Cody, 05-10-2004 20:57:11
it was russell's
Cody
05-11-2004 20:57:06
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: EXPLOSION in reply to farmall, 05-11-2004 15:10:56
Tough break, atleast parts are plentiful and cheap for his engines.
