Engine blocks
farmall flogger
12-06-2001 20:10:49
What do most of you guy's rules say about engine blocks, say a 264 or 281 on an M, or a D-17 on a WC, or JD powerblocks? Is it allowed or not?
burns
12-07-2001 07:00:39
 Re: engine blocks in reply to farmall flogger, 12-06-2001 20:10:49
32. Tractor motor and chassis must conform with each other and must be O.E.M.
As you can see our rules are rather open. We do not follow the strict rules for NATPA and we don't have high hp tractors like a 800 MM.
farmall fogger
12-09-2001 08:34:06
 Re: Re: engine blocks in reply to burns, 12-07-2001 07:00:39
So Burns you wouldn't have any problem pulling against an M with a Super M, 400, or 450 motor? Some guys in our assoc. are crying about it. As hard as these parts are getting to find I kinda like having an option. And by the way Burns I always enjoy your comments, no matter what the brand.
burns
12-10-2001 03:00:52
 Re: Re: Re: engine blocks in reply to farmall fogger, 12-09-2001 08:34:06
No, because my brother in law and I just finished a 1939 M which was purchased with a block from a W-6 tractor installed. As I am sure you are aware, it is virtually the same as a M block. I don't think you can drop a W-9 block in say a model H.
Isn't it strange how easy it is with a little machining to drop the oversize sleeves for the 264 block into a M block.
MM
12-07-2001 14:59:01
Sounds like more brand spec. rules to me. What about open or div 4 or 5 rules?
burns
12-10-2001 02:53:29
 Re: Re: Re: engine blocks in reply to MM, 12-07-2001 14:59:01
MM, the engine rule I mentioned was for a stock class. Sorry for the misunderstanding. Here is a link to our rules.
G Taylor ........cradled drawbar?
12-10-2001 21:01:16
 Re: Re: Re: Re: engine blocks in reply to burns, 12-10-2001 02:53:29
Rule #30 mentions drawbar supports & cradling? What is cradling when supporting above axle height?
farmall flogger
12-09-2001 14:43:56
I think they're talking mainly about the stock class, but I'm not postive. Personally I think the bolt on OEM stuff is fine, and apparently it's OK to bore and stroke Your "correct" block. I think it's a rule that will be hard to enforce. There will be a lot of grinding off of numbers and other ways of getting around it. They're basically taking something simple and making it complicated.
