Glad to hear you done well, Sounds like you have a good running Super M to make the governor surge! You are not using the HP you have at that light of weight. But, there is a solution, and I have to ask you a few questions to try and help. 1, do you have a 2 weight or a 4 weight governor? 2. what rpm are you running, and gear. 3. how many hp is it? rough estimate.. 4, what size tires do you have, and allowed to run?What I am seeing here is that you have power, but not working the engine enough to make it hook, and not surge. A few things can help, Tire size affects ground speed, when you speed up, you use more power to run a bit faster. It works on the same principal, as weighting up. Tire pressure will help too. At this time, this is the best advice I can give you, Surging is caused by too much power, and worn governor weight pins. Hope this helps, ChadS
