Double tree pulling (simple solution)
richard
12-07-2001 11:14:57
you pullers in the 2 light classes(2500-3000) should take a look at this type of pulling. you would have 2 tractors hooked to sled instead of 1. also you would not need to have a 3500 class(you probably don't have the weights to get that heavy anyway). hopefully this helps you guys get the sled moving easier unless you are pulling on a greasy track(better check weather forcast before you leave) let me know if this helps. later richard
