ChadS, spring info
Sweeper
05-18-2004 19:29:11
I talked to your dad today about a spring for a 460 govt. Need to get more rpms. If you have info, e-mail me at jbmbsweeper@earthlink.net Thanks.
Sweeper
05-19-2004 19:44:43
 Re: ChadS, spring info in reply to Sweeper, 05-18-2004 19:29:11
ChadS, all I had to do was ask you and everyone else would give these brillant ideas.
ChadS
05-21-2004 05:11:29
 Re: Re: ChadS, spring info in reply to Sweeper, 05-19-2004 19:44:43
Where there is a will, there is a way my friend. Good luck!! I am having good luck with the combine governors, 2900 rpm stock before any adjustments. with the stock 460 linkage. I have to park the ol 460H for a while,,, Got 2 H farmalls I have to weight up to 5500 just to pull the sled 50 ft!!! I cant wait to see what the "Farmstock H will look like with 5 sets of weights on each side of the wheels, 14.9X38's, in 1st gear!! Should hook up and pull!! Don't ya think? PS, tell Eddie Haskel, any time he wants to try to put that 440, in that cub frame,, I have a spare cub frame and a 440 and a welder, a big hammer and a few rolls of duct tape!! See ya fellas!!! ChadS
Hillbilly Hooker
05-18-2004 20:28:07
Hey Sweeper and the Miss. Mafia. Are yall coming to Arkansas to pull with us Saturday? I can show you a real simple way to get more rpms on the 460 governor and it will still work normal. I did it to my old 460 and it would turn 4000 or better. Pull Sat is at St Francis Ar. Rules pretty much same as ours. H.H.
Sweeper
05-19-2004 19:51:21
 Re: Re: ChadS, spring info in reply to Hillbilly Hooker, 05-18-2004 20:28:07
Saving my kitchen pass for Melbourn the week after Memoral day. My M and old Chev truck are in fine tune right now. That could change without notice.
Eddie Haskell
05-19-2004 04:51:44
 Re: Re: ChadS, spring info in reply to Hillbilly , 05-18-2004 20:28:07
Looks like the Mafia will be represented by a JD G from Tunica, JD A from Southaven, Super M from Hernando and our adopted JD G from Turner, AR.
Hillbilly Hooker
05-19-2004 20:34:39
 Re: Re: Re: ChadS, spring info in reply to Eddie Haskell, 05-19-2004 04:51:44
Eddie, glad to hear some of yall are coming. See yall there. H.H.
ChadS
05-18-2004 20:02:25
I run one on the 460, will turn about 3000 easily. I run a combine governor,, it is a single lever governor, with a deadman throttle, Works pretty good, If rpm you need, We may have a spring for it. , Might come down to Tunica, I hear it is all business there. ChadS
Eddie Haskell
05-18-2004 19:36:08
Are you helping out "Two-Way Pulling Team"?
Sweeper
05-18-2004 19:38:50
 Re: Re: ChadS, spring info in reply to Eddie Haskell, 05-18-2004 19:36:08
I think they want to cheat.
Sweeper
05-18-2004 19:50:55
 Re: Re: Re: ChadS, spring info in reply to Sweeper, 05-18-2004 19:38:50
Hey Eddie, do you think we could talk ole ChadS into comming to Tunica, Ms. the first weekend in Dec? He could bring his dog and pony show(H-460) and show us how to pull, the rest of the yankies seem to do a real good job of it.
notslip
05-19-2004 05:30:04
 Re: Re: Re: Re: ChadS, spring info in reply to Sweeper, 05-18-2004 19:50:55
i use a screen door spring on my U, have a extra if need it
rule bender
05-19-2004 09:43:07
 Re: Re: Re: Re: Re: ChadS, spring info in reply to notslip, 05-19-2004 05:30:04
what,s a governor? sounds political to me!
Ol Gray A
05-19-2004 16:32:15
 Re: Re: Re: Re: Re: Re: ChadS, spring info in reply to rule bender, 05-19-2004 09:43:07
Sweeper , what do you need a govenor spring for? I though you controlled it by Hand!!!!! !!!!
Sweeper
05-19-2004 19:42:10
 Re: Re: Re: Re: Re: Re: Re: ChadS, spring info in reply to Ol Gray A, 05-19-2004 16:32:15
Not my tractor. It belongs to Ricky Broadway and Terry Treadway, I named them Two-Way Pulling. I am just helping out.
Ol Gray A
05-20-2004 04:00:53
 Re: Re: Re: Re: Re: Re: Re: Re: ChadS, spring info in reply to Sweeper, 05-19-2004 19:42:10
Ohhhhh, so you are goona make sure they can't beat you!!!!! !!!!
