JD power block
A puller
05-25-2004 19:43:21
Does any one know how much a stock A powerblock can be bored out? Does it have to be resleeved to get 6.5 bore? What is max on the standard JD block? Also what is the most stroke that will fit?
stroke
05-26-2004 05:33:10
 Re: JD power block in reply to A puller, 05-25-2004 19:43:21
There's an A out there somewhere with a 10.125" stroke. You'll have to move the cam though. One pulls with us that has a 9.25" stroke.
a puller
05-25-2004 20:59:06
6.125 stock p.b., 5 7/8 (5.875) on a stock block, and however much stroke u desire..ours is 7.25 and is a real small build from what I've heard..... has .125 pistons...58hp...last we checked....but it has picked up a lil....and then went down due to gettin water now..:S....have to dyno it again.
Adam B.
05-25-2004 22:45:04
 Re: Re: JD power block in reply to a puller, 05-25-2004 20:59:06
Where are you getting power block pistons from..custom engine shop or something resembling a retail business?
I called about pistons for a B power block from a supplier of reproduction/restoration engine parts, but never heard back from them. They said they'd get in touch with me once they had enough orders to do a production run...that was quite a while ago. An engine builder I got a number for said it'd cost around $350 each to custom build the pistons (I'd have to provide them with sample pistons to work from or blueprints). That isn't really a viable option for me, but I am interested in using a power block I picked up. It's in good condition (not cracked) but didn't have the pistons with it.
Thanks.
520-LP
05-26-2004 20:17:38
 Re: Re: Re: JD power block in reply to Adam B., 05-25-2004 22:45:04
Hinnrich Repair has power block pistons in standard,.045,.090 a set of pistons,pins and rings for an A was around $650.00 with shipping 4 months ago very good quality [815-778-1900]
