Farmall M
Tom
05-27-2004 18:52:12
Hello I was wondering if you guys could tell me what it took and what is involed in putting a V-8 in a M ( I know you guys don't like to tell all the serects but please help alittle). What motor would be best? Will the rearend take it? What about lining up your clutch and drive shaft? Please help
Thanks
donkster
05-28-2004 15:58:27
 Re: Farmall M in reply to Tom, 05-27-2004 18:52:12
doin the same thing,moiser engineering is cutting
input shaft 4 my mta with common chevy clutch splines and correct length. will have to run chevy flywheel and clutch. starter is a pain in the butt. frame rails will need to be trimmed at the flywheel housing to get top bolts in. a oliver,massey harris or f series farmalls are tractors of choice for this because of simpicity.hope this helps cause i had to figure it out myself
