HEY ChadS H Questions
CLIFF
06-07-2004 11:26:38
How does a 8043 head compare to a 300 or 350 gas head? also can a H block be inlarged to accept the C175 sleves withought beening to thin. what would do without stoking it. to be used for a div 2/3 tractor. and what HP should i expect. thanks cliff.
ChadS
06-07-2004 11:54:20
 Re: HEY ChadS H Questions in reply to CLIFF, 06-07-2004 11:26:38
There is a casting difference between them in the combustion chamber. There is 2 heads with the 8043 part number, 8043d and 8043dd. The d is the older head, and the dd is the newer version, then it goes in to the 300-350 casting numbers. There is a difference in the 8043d, and the 8043dd, and the 300-350 heads. it is the compression chamber, the newer heads,, were desiged for firecrater pistons, and have a slight indention along one side of the chamber, to make room for the higher dome on the piston. Also, the intake runners on the dd and the 300-350 are a bit larger than the 8043d. The H block can handle the C-175 sleeves easily. It will have plenty of block left, just watch the ring on the top of the sleeves, for the H block will have to be bored for that diameter of sleeve, or simply machine the ring of the sleeve down,, so the H block will be stronger yet. Use the 175 head gasket for the larger bore, instead of the H, it has a larger bore in the fire ring in the gasket. If you just put the engine together, no milling of the head, and fire craters,, if that is what they offer for piston selection. Also the super H and 350 manifold and carb, carb would have to be tuned to get the fuel right,, 50-53 hp at 540. Lp head would be a bit stronger, but alot of $$$, You could probably go out and plow with it all day long as far as reliability is concerned. Hope this helps. ChadS
CLIFF
06-07-2004 18:35:08
 Re: Re: HEY ChadS H Questions in reply to ChadS, 06-07-2004 11:54:20
MY TRACTOR IS A 1947 AND HAS THE LATER CASTING HEAD. SHULD I THINK ABOUT ROLLER ROCKERS ? IF SO WHAT 1.7 OR 1.9 ? THANKS FOR YOUR HELP. CLIFF
ChadS
06-08-2004 07:42:50
 Re: Re: Re: HEY ChadS H Questions in reply to CLIFF, 06-07-2004 18:35:08
Use the stock rocker assembly, you wont see a difference in a Farmall that runs stock rpm, or 10 over. There is other performance options to choose from to step it up. Cams are a touchy subject, cause there is a load of different grinds from stock to custom cuts that work and then some that dont. The purpose is to make as much cyl pressure as possible. and the valve lash adjustment can build up the pressure in the cyl. I like to set them with a compression guage, 1 cyl at a time, I tighten up the lash until the pressure peaks,, then that is the lash setting, usually it is around .011-.013 hot, it is a longer process to set them this way, but the most benificial in my opinion. Wanna hear more?? ChadS
CLIFF
06-08-2004 18:36:21
 Re: Re: Re: Re: HEY ChadS H Questions in reply to ChadS, 06-08-2004 07:42:50
YEA I DO
