Copper head gskt. sealer?
RB
06-08-2004 11:18:18
Anyone have any suggestions or experience using sealer. I use Gold N Seal on other gskts. and it works well but I'm not sure about it for copper. This gskt. is being used on a DT466 IH engine. Thanks!
Heavy Puller
06-09-2004 09:12:38
 Re: Copper head gskt. sealer? in reply to RB, 06-08-2004 11:18:18
Hussey Copper made my gasket and they recomended Threebond 1104 for best results hard to get unless you want a case of it but I later found out that it is the same as Yamabond motorcycle case sealant hope that helps.But they also said Hylomar works also but the 1104 works better.
Shutt30
06-09-2004 21:03:48
 Re: Re: Copper head gskt. sealer? in reply to Heavy Puller, 06-09-2004 09:12:38
Yamabond seals real good but once its cured its a bugger to get back apart. Never used it on a gasket. Always metal to metal on crankcases. I use 1104 all the time on snowmobile engines and outboards. The local machine shop builds alot of drag engines and late model stock car engines and hylomar is what they use. Now you got me thinking which one am I going to use on mine?
Heavy Puller
06-10-2004 05:38:54
 Re: Re: Re: Copper head gskt. sealer? in reply to Shutt30, 06-09-2004 21:03:48
I know what your saying Bob at Hussey is the one that recomended it he was selling me the gaskets and said that he sold hylomar but said the 1104 works best and he didn't sell it .Give him a call real nice people I got a 6cyl..042 for $65.
http://www.husseycopper.com/gasket%20site/contact.htm
Shutt30
06-08-2004 19:28:03
Permatex hylomar aerosol gasket sealant. Says for all type of gaskets. Even says copperhead gaskets on the side of can. my .02
Brandon
06-09-2004 12:38:11
 Re: Re: Copper head gskt. sealer? in reply to Shutt30, 06-08-2004 19:28:03
I Have a moline that i use copper headgaskets on and I use Coppercoat. It come in a areosal can and you just hang your gasket up and spray both side and we also spray the deck and the bottom of the heads.Brandon
