5th gear makes a howling noise
adam
06-15-2004 18:39:19
I have a superH that when I have it in 5th gear it makes a howling noise . is it a bearing or a gear ? when I drained the oil out some pieces of a bearing came out where should I start looking?
heavey c
06-16-2004 07:34:45
 Re: 5th gear makes a howling noise in reply to adam, 06-15-2004 18:39:19
i had an m and it spun a brake pinion bearing
ChadS
06-17-2004 08:53:01
 Re: Re: 5th gear makes a howling noise in reply to heavey c, 06-16-2004 07:34:45
Yep, it does sound like the brake pinion bearings to me as well, also, the pig where the bearings attatch to the differential, the bearing race, may be broke off the pig!! it will still move,,, but will make it like a brake is sticking when you first move the tractor from a stop, it will howl, clunk, and carry on, ChadS
