Building a Deere
Milt
06-18-2004 12:13:39
Is it possible to build a two cylinder John Deere that can compete with Olivers and Farmalls in a open 5 mph class. If so, what would have to be done.
G-MAN
06-19-2004 07:37:36
 Re: Building a Deere in reply to Milt, 06-18-2004 12:13:39
Just keep in mind that because it's a 5 mph class does not mean you HAVE to be able to run 5 mph to compete. If you build a good strong tractor, set it up right and can drive it right, you could win a 5 mph class at 2.5 mph. It's not how fast you go, it's how far you go, or they'd call it tractor racing instead of tractor pulling.
Phil Munson
06-19-2004 11:28:06
 Re: Re: Building a Deere in reply to G-MAN, 06-19-2004 07:37:36
Last summer I watched a late production JD B, in first gear, a division one tractor, beat "all the big boys" in the 5500 class at a good pull in upstate NY.
You are so correct. It ain't how fast, it is how far. This, guy mentioned above, read the track just right, and at 1.5 MPH hauled it the farthest that day.
A puller
06-18-2004 16:26:19
Our Unstyled A has beat alot of Wk-40, 460, 88, 77 in 5 mph 4500 to 5500 classes. It depends on the track more than anything. We run in 2nd gear in all class which is alittle over 4mph, it still stay with avery one else.
CASEPOWER
06-18-2004 12:46:22
I published a story by: David Wickman in Old Power Pride June issue about "Yellow Jacket" and "Double Trouble", two unstyled B's. I had spoke to some people that have seen them pull in 4 mph modified class and they are very tough to beat from what they tell me. He has bored and stroked both of them and he tells what he put in them and how far he went. E-mail me your address and I will send you a free June issue.
oldpowerpride@earthlink.net
JDGnut
06-19-2004 22:13:22
 Re: Re: Building a Deere in reply to CASEPOWER, 06-18-2004 12:46:22
Casepower... how can I get a copy.. (I'll send U an email.)
I have driven both of his tractors.. They have figured out the tricks to those little tractors... The Yelow Jacket has been together for a long time with no problems and is still very competitive. JDGnut
David
06-19-2004 14:51:16
When was the June issue sent out, as I have not received mine yet?
CASEPOWER
06-19-2004 17:36:27
 Re: Re: Re: Building a Deere in reply to David, 06-19-2004 14:51:16
It was late as we had to reprint. Should have it anytime. Bulk rate mail is slow anyway. If you don't get it in a few days e-mail me.
John
06-20-2004 14:44:40
 Re: Re: Re: Re: Building a Deere in reply to CASEPOWER, 06-19-2004 17:36:27
I would like an issue also. I am looking for an unstyled A to pull with. Im sure the info would be very helpful.THank you, John
CASEPOWER
06-20-2004 17:50:25
 Re: Re: Re: Re: Re: Building a Deere in reply to John, 06-20-2004 14:44:40
You will have to e-mail me your address. Jonathan oldpowerpride@earthlink.net
