Piston clearance
T L Bair
03-31-2001 15:08:04
What sort of piston to wall clearance is adviseable with aluminum pistons and cast iron
wet sleeves. Thank you for your help.
Dick L
03-31-2001 15:53:09
 Re: piston clearance in reply to T L Bair, 03-31-2001 15:08:04
.003 to .004 feeler gage between the piston and sleeve is good. I don't use any thing I can more than .010 down the side in the 3 1/4" to 4" pistons. The bigger pistons like for JD A's and B's .005 to .008 . I don't know what the outter limits are on them.
T L Bair
04-01-2001 15:51:05
 Re: Re: piston clearance in reply to Dick L, 03-31-2001 15:53:09
Thanks for your help Dick. Thats what my service
manual says for cast iron pistons I just wasn't
sure for aluminum.
Gman413@worldnet.att.net
04-01-2001 19:35:29
 Re: Re: Re: piston clearance in reply to T L Bair, 04-01-2001 15:51:05
Mr. Blair I put a set of Alum. Pistons in a "G" and the supplier recommended a min of ten thous. for Alum. Piston,on my puller with custom piston I run a clearance of eighteen thousands with total seal rings. Might not be a bad idea to check with piston suppler and see what they recommend,might save you some ack and pains. Gman
DougS
04-02-2001 11:40:30
 Re: Re: Re: Re: piston clearance in reply to Gman413@worldnet.att.net, 04-01-2001 19:35:29
Gman is right...On aluminum piston allow .001 per inch of piston diam. A 6.5 inch piston will have .013 total clearance. I.E...6.5" diam times .001 equals .0065, .0065 times 2 (point A to B across bore) equals .013. This formula generally works across the board, but check the data with each piston manufacturer.
