Earlystyled A with late styled MW pistons and Heisler head
Jim V
12-17-2001 23:10:29
I am building a low buck puller and was wondering if it will make a noticable change in horsepower if I put late styled M&W pistons in my early styled "A" with a heisler head. And if I will have to have any machining done to make it work. Will this give me too much compression? Thanks to all who reply . Jim
John
12-21-2001 09:30:03
 Re: Earlystyled A with late styled MW pistons and Heisler head in reply to Jim V, 12-17-2001 23:10:29
ya, it should make a difference the pistons part, but I don't hardly know what the "heisler" head will do if any.
Todd
12-20-2001 11:04:15
In my experience, stay 150-185 lbs. cranking speed. 200+ seems to fight against you, and won't have that good JD lug. Just an opinion.
Gman
12-18-2001 18:22:30
Jim V. the high compression sounds impressive but I got a "G" eat up with compression and my plow tractor out pulls it. Cubic inches and rpm's is the name of the game for power. A mild stroke and large valves and big exhaust will go along way. Gman
Burns you better read
12-20-2001 07:35:57
 Re: Re: Earlystyled A with late styled MW pistons and Heisler head in reply to Gman, 12-18-2001 18:22:30
Burns says HIGH compression is the only way to go. Your Plow tractor is full of crap
hey
12-21-2001 09:25:46
 Re: Re: Re: Earlystyled A with late styled MW pistons and Heisler head in reply to Burns you better read, 12-20-2001 07:35:57
not really. High compression is working against itself most of the time, but it also depends on how much compression is HIGH compression to you.
AGREE
12-19-2001 19:25:09
