100lbs on front is 400 on back
potter
07-03-2004 16:46:09
is this true? can you put to much weight on front and lose the traction ? my front end comes way up should I put 100 lbs on the front and take it off the back or drp my hitch and inch or so help new puller Potter
Lamont
07-04-2004 07:05:54
 Re: 100lbs on front is 400 on back in reply to potter, 07-03-2004 16:46:09
My thoughts are that you want to put all the weight of the tractor, (as much as possible anyway), on the rear tires but at the same time the drawbar needs to stay at maximum height. Picture the drawbar as "lifting" the sled. Lift the sled, reduce the drag. If your front is coming up, your drawbar is going down, therefore reducing lift on the sled, thus increasing drag. Try to put enough weight on the front to just make the front barely stay down. I don't want my tractor to lift the front wheels more than 2 inches. High "wheelies" make good pictures but very few full pulls. You just have to decide if you want pictures or trophies.
