Farmall H weight?
Dennis
12-19-2001 13:06:13
My friend recently bought an H. He was wondering how much it weighs roughly. It is all stock with a narrow front end.I think it is a 1948. What pulling class would he be in? Thanks, Dennis.
Seth Roemer
12-19-2001 14:21:41
 Re: Farmall H weight? in reply to Dennis, 12-19-2001 13:06:13
I have a 1948 H and it weights 4300lbs. with two 150 wheel weights, and 10 gallons of gas. It will do good in the 4500lbs. class, but if you go to the higher classes, your better off to get a M.
BigRed
12-20-2001 13:07:51
 Re: Re: Farmall H weight? in reply to Seth Roemer, 12-19-2001 14:21:41
My 1947 H wt. is 3900# 500# and my self fits in the 4600# class fine. I see no esey way to get into 3600# class. On soft track with slippage I do fine but hard tracks am beat by larger h.p. tractors. I run 13.6 x 38 tires, some think I would not power out with stander size tires. Motor overhauled but nothing extra. Was tould I could not win with a H but their not saying that very loud now that I won 3rd in my wt. class for the year. Good Luck
dan
12-23-2001 18:39:19
 Re: Re: Re: Farmall H weight? in reply to BigRed, 12-20-2001 13:07:51
I know that they get farmall H 's down to 3500 lb class.
Big Red
12-24-2001 07:09:41
 Re: Re: Re: Re: Farmall H weight? in reply to dan, 12-23-2001 18:39:19
I would like to know what thay do to get the H down to 3500# ?
ken
12-24-2001 12:08:05
 Re: Re: Re: Re: Re: Farmall H weight? in reply to Big Red, 12-24-2001 07:09:41
steel press wheels and a good stripping
B J
12-24-2001 20:33:04
 Re: Re: Re: Re: Re: Re: Farmall H weight? in reply to ken, 12-24-2001 12:08:05
We have had a couple of people in our area get away from the wheel issue by using cutdown wheels from a F14 ( I think ) they have a wavy center that is steel (not cast iron) with flat spokes and just like the M guy's remove the hydraulic pump and belt pulley gear box if the tractor is equipped with them, put somebody light in the seat and make the 3500 lb. class
BIGRED
12-24-2001 20:08:52
THANKS FOR THE INFO, THEIR IS SOME QUESHION IF PRESSED WHEELS ARE O.K. IN OUR RULES, PRESSED WHEELS HAS TO BE LISTED IN I.H. PARTS BOOK AS STANDARED OR SPECIAL EQUIP. I HAVE NOT BEEN ABLE TO FIND THIS INFO.
