How Much HP for div 3 ?
carl
12-20-2001 17:15:51
I am going to run div 3 how much horsepower does it take most of the time. on an average track? Thanks
ken
12-20-2001 19:50:35
 Re: How Much HP for div 3 ? in reply to carl, 12-20-2001 17:15:51
Carl it's not just HP in any class and any weight . It more than that. ask again Ill tell you more ?
ken
12-20-2001 19:49:46
Carl
12-21-2001 04:10:12
 Re: Re: How Much HP for div 3 ? in reply to ken, 12-20-2001 19:49:46
I want to pull div 3 4500 lb and 5500 lb class and how much power will it take on an average track???
deere puller
12-21-2001 05:26:22
 Re: Re: Re: How Much HP for div 3 ? in reply to Carl, 12-21-2001 04:10:12
what kind of tractor? I've got a G JD that used to pull Div. 3, about 90 horse and it's more than enough for second gear in 5500 and 6000.
Jack
12-21-2001 09:44:48
 Re: Re: Re: Re: How Much HP for div 3 ? in reply to deere puller, 12-21-2001 05:26:22
Are you running a stroker crank in your G?
deere puller
12-21-2001 12:51:57
 Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to Jack, 12-21-2001 09:44:48
Stroker crank, gas pistons, head/carb/manifold all flowed.
art
12-22-2001 18:42:06
 Re: Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to deere puller, 12-21-2001 12:51:57
You need enough power to run 3.5mph in a gear that runs your engine at about half throttle but you have enough extra power so that as the weight travels farther and it becomes more difficult to pull you can keep opening the throttle gradually and maintain your speed without overpowering the track and spinning out. The idea is to maintain without spinning your tires yet have enough power to not bog down. Horsepower is only part of the answer. Tires and weighting are equally important and you must have all three. To answer your question we have an 88 with 150hp in division 3 and a U with about 110hp. Both work quite well. aRt
sam
12-24-2001 06:02:01
 Re: Re: Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to art, 12-22-2001 18:42:06
ANOTHER gingerich customer slowly fading into div 3! I bet that is fun pulling that 150 hp (?????) 88 against all those 100 hp or less tractors who div 3 was set up for!! You should be really proud with a win!!
guy
12-24-2001 06:32:22
 Re: Re: Re: Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to sam, 12-24-2001 06:02:01
get lost, it doesn't matter if you have 800 horsepower when you have the speed limit.
sam
12-24-2001 08:11:00
 Re: Re: Re: Re: Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to guy, 12-24-2001 06:32:22
That's NOT the point! I was noting how a "devout Gingerich boy" was now laying that HP stomping Plain City material into Div 3. I'm sure that'll make Lawrence proud!!!
A.P.
12-24-2001 11:16:46
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to sam, 12-24-2001 08:11:00
Yeah all that obsolete high priced iron from Lemmons, Duke, Shipman, Denny's (okay so the post needed a bit of humor), etc. winds up in division 3. Big surprise there. This is been going on for how many years now?
mike
12-25-2001 07:25:42
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: How Much HP for div 3 ? in reply to A.P., 12-24-2001 11:16:46
NO, a little humor would have been if you said Bob Sharp!! Where has Bobby been lately, anyone know? Is he still trying to build engines??
