Heavy puller
Jon
07-20-2004 20:42:24
Hi! Just curious what is the heaviest antique pulling tractor any of you have seen? that being 1957 or older. And if it was transfer sled pull or derby type? Thanks
Stretch
07-23-2004 10:58:21
 Re: Heavy puller in reply to Jon, 07-20-2004 20:42:24
Up here in Northern Vermont we go up to 14000#. Two years ago a JD60, with that slow (creeper) first gear, freighted up with weights and took the class beating JD830's, JD80's, Oliver 99's and Massey's.
David
07-21-2004 14:54:34
We pull a 16500# class her in GA
720Deere
07-21-2004 05:45:24
The heaviest class that we pull here in MD & southeast PA is 12500. I have seen Farmall Ms, JD 620, 720 80/820/830 Oliver 88s and even an occasional JD G. This is on a transfer sled.
Dieselbear
07-21-2004 06:56:52
 Re: Re: Heavy puller in reply to 720Deere, 07-21-2004 05:45:24
They pull a 13,500 @ Westminster, Md in a farm stock class, We pull a Minneapolis Moline GB In. It takes all the room we have to put that much weight on. Glenn
JDGnut
07-21-2004 13:39:12
 Re: Re: Re: Heavy puller in reply to Dieselbear, 07-21-2004 06:56:52
We used to have some 80-830's.. and a few Oliver 1900's that used to pull in an unlimited weight class... Most were in the 24,000lbs range... I think the Heaviest we ever had a tractor was about 16,000lbs...
JDGnut
