Max rpm
burns
04-01-2001 14:14:26
I was talking with a puller the other day and we were discussing rules on RPM. One thing led to another and he started to tell me one of those "I know this guy" stories. The shorten version was that this friend of his was turning his Farmall M a little under 4000 rpm. Kind of have my doubts about the longevity of the motor but who knows. I was wondering what the max rpms you pull if you are not governed by a rule like 10% or something. I have turned my G at 2000 rpms for a short period of time but have decided to limit my rpms to no more than 1300-1400 max. Any thoughts on your brand/model of tractor?
Cookie
04-05-2001 05:10:10
 Re: max rpm in reply to burns, 04-01-2001 14:14:26
I have a cockshutt 40 that i have been pulling for the past 12 years.The only thing I have done to the motor since the rebuild in 89 is that I took 3 of the 6 gov. weight's out and put a tighter spring on.This allows the motor to turn 3200 rpm's put a peice of wire on the spring and it will turn 5000 plus.
Jake
04-03-2001 09:06:39
I have a stock MH 44-4 that will turn 3200 rpms without any problems. Of course that is only to about 1/2 track. lol
cockshutt
04-03-2001 06:46:18
I pull a cockshutt 50 bored and head work no stroke and I run it at about 4600. It's been pulling at that for about 4 years never overhauled it yet?
lonn
04-02-2001 18:26:26
There is a guy here that runs a WC at 5000 rpm with lots of compression. He does well but split the block once from end to end.
Bryon
04-02-2001 13:52:47
Told one of the guys we pull with that my stock M ran 2000 rpm turned clear out. He just raise his eyebrows. Don't really like to do that though. She shakes and vibrates. Only suppose to run 10% or 35% anyway.
MN.MM
04-02-2001 05:33:36
I WOULD LIKE TO SEE THAT 70 PULL, IT MUST BE UN REAL. IF THE FLYWHEEL CAME OFF AT 4000 RPM, HOW MANY MILES WOULD IT GET BEFORE IT STOPPED? HAHAHA
JDGnut
04-02-2001 14:57:48
 Re: Re: max rpm in reply to MN.MM, 04-02-2001 05:33:36
I know what U mean MM.. I headr about a flywheel coming off a JD once and ran down the track and out the door... hahaa.. On the 70 he is running a billet whywheel, so it should not come apart.. and he has is shielded with thicker material.. It is an ugly tractor.. but suppose to be wild ride.. has to get the RR's up there to get a smoother flow of air.. Those 2 bangers, sure have a long time of delay between the firing of the 2 cylinder, until #1 comes back around to fire again...
Later.
JDGnut
MN.MM
04-01-2001 18:47:35
THERE IS A 4200 RPM MM "U" UP HERE IN THE NORTH COUNTRY. IT SEEMS TO BE PRETTY RELIABLE. I RUN MINE AROUND 2200.
JDGnut
04-01-2001 20:19:06
 Re: Re: max rpm in reply to MN.MM, 04-01-2001 18:47:35
I had Tech in my class a few weeks ago that used to pull an old MM years ago.. I think he was turning 7000-8000 R's with the old girl.. I can't remember the size.. U or UB.. or something like that, it was a 4 cylinder.. Of course.. it was turbo charged, burning.. Alcohol.. running about 75Lbs of boost.. I think he was pulling in the Pro-Stock class.. JDGnut
JDGnut
04-01-2001 20:21:08
 Re: Re: Re: max rpm in reply to JDGnut, 04-01-2001 20:19:06
Oh yea.. I forgot to mention the turbo charged JD 70D that has been pictured in the Hook Mag.. I can't remember the R's.. but I think it was 3000 or 4000... JDGnut
Tractor Rod
04-02-2001 16:17:31
 Re: Re: Re: Re: max rpm in reply to JDGnut, 04-01-2001 20:21:08
We run a unstyled WC and run that between 3500 and 4000 rpms.We have been running it for eight years that way. Never had a problam
CC
04-03-2001 16:51:23
 Re: Re: Re: Re: Re: max rpm in reply to Tractor Rod, 04-02-2001 16:17:31
We ran a JD 60 at 100% + over on rpm's for more than 20 years and never had any engine problems. There were also several other tractors such as G's, M's, etc. running just as wild.
tyler
04-03-2001 18:22:31
 Re: Re: Re: Re: Re: Re: max rpm in reply to CC, 04-03-2001 16:51:23
We ran an 1100 massy motor in an 88 that ran about 5000, we sold it and the guy that bought is is still running it without it ever haven been torn down. It is 425. we put it together in 1993.
