Cam shaft grinding
Don Ruscha
12-24-2001 07:13:17
Who is the best at helping set up the specs. & at grinding a cam for pulling. Thanks!
Jrred
12-27-2001 06:58:06
 Re: cam shaft grinding in reply to Don Ruscha, 12-24-2001 07:13:17
Try crower cam in CA if you know what you want to run for rpm they can help! do not know the # off hand but I'm sure you can find it on the net
Vinnie Vitner
12-26-2001 16:02:11
Try Camcraft 8004262261 or Custom Built 5152953775 I built a CC case years ago before someone took it.
Don Ruscha
12-28-2001 17:12:00
 Re: Re: cam shaft grinding in reply to Vinnie Vitner, 12-26-2001 16:02:11
I think I know the tractor you are talking about. It used to be a real bad machine. The last I knew about it it needed a little tuning & it still would be BAD.
Vitner
12-30-2001 05:26:30
 Re: Re: Re: cam shaft grinding in reply to Don Ruscha, 12-28-2001 17:12:00
Hey Don is it still painted up like new.
Don Ruscha
12-30-2001 10:52:14
 Re: Re: Re: Re: cam shaft grinding in reply to Vitner, 12-30-2001 05:26:30
It needs to have that guy in Verona that is a custom painter redo it. The only thing is his health is not too good I understand. Do you have any pull with him? If you would give him a gift for me he might give the old case a paint job.
Vinnie Vitner
12-26-2001 16:00:22
Grease Monkey
01-01-2002 08:58:35
 Re: Re: cam shaft grinding in reply to Vinnie Vitner, 12-26-2001 16:00:22
I tell you what, you all just keep sitting around eating potato chips. I've got a pulling tractor to build. Just be sure you don't choke on my dust while you're stuffing your faces!
