John Deere H
gary
12-24-2001 10:24:19
just wondering if there were any other
people out into pulling the little John Deere H like to hear from your gary.
phil
12-27-2001 08:19:16
 Re: John Deere H in reply to gary, 12-24-2001 10:24:19
Gary, I pull with my stock 1940 JD H. In many ways it is more fun to pull than my bigger tractor. I belted up to a Baker Fan so that I could adjust the carb with the tracter under full load. I made some spacers to raise the drawbar about 2", and I use about 7 psi in the rear tires. That setup usually gets the front end to lift during the last 10 feet or so. Have fun!
gary
12-30-2001 09:00:41
 Re: Re: John Deere H in reply to phil, 12-27-2001 08:19:16
phil I was wondering I'm from Michigan
where you from?
gary
12-30-2001 08:56:31
hay phil
it's good to here that I'm not the only one
crazy enough in to play with the little h
I pulled a case vac for many years
recently started playing with the little John Deere everyone thinks I might as well step up to a different model
something with more power I've done a lot of work on this little tractor
trying to make it competitive
everyone tells me you just cannot produce the power you need out of it
I'm having a great time proving them wrong
I'm not one that likes to really modify a nice old tractor
but this little h I found
had every problem in the world with it
so it was a good experimental tractor I thought
I've been doing fairly well with it
having a blast I think there should be a place
for every model tractor to pull in
you have any photographs of yours?
like to see them gary.
