Max STROKE
JDG
12-24-2001 10:40:41
What is the max stroke that a person could get out of a JDG? What do you think max. horse power could be? I want to make my G put out the max...and I need to know how to get to that max. And what MAX is.
Thanks you.
Richie Rich
12-25-2001 00:09:04
 Re: Max STROKE in reply to JDG, 12-24-2001 10:40:41
How much money you got?
deere puller
12-24-2001 16:40:56
Max is whatever you want to make it. There are G's out there with over 10 inch strokes. If you want to move the cam 11+ inch strokes are possible. Blocks are being made with 7.5" bores, but that's only because they decided to stop at that size. Bigger is possible. So however much you want to spend and how open minded you are at making it work are the only real limits.
ollie man
12-24-2001 19:43:17
 Re: Re: Max STROKE in reply to deere puller, 12-24-2001 16:40:56
Max is pullin with an oliver cause they rule the track
MMREDGREEN
12-30-2001 08:00:42
 Re: Re: Re: Max STROKE in reply to ollie man, 12-24-2001 19:43:17
I don't believe the question pertained to Olivers. All I know is that you can get 900 cu.in. and the only tech I can offer is it used two spacer plate and a lot of grinding. If I knew more how he did it I would pass it on, but I don't. But hopefully its more than "Oliver's rule dude".
