How much compression
70
12-25-2001 16:41:41
I am setting on 120 psi. now. What is the best compression for a pulling tractor . Can you get to high and hurt preformance . I plan to go to 200 -225 . Would like some input . thanks Ken
psi
12-26-2001 17:49:23
 Re: How much compression in reply to 70, 12-25-2001 16:41:41
150-185psi is best luck for me. anything over 190-210 seems to hurt the power
G Taylor
12-26-2001 09:50:13
Compression pressure is not a sign of compression ratio alone. Cam timing is also a factor. What is the tractors current mechanical comp ratio when measured out with a burret & a peice of pexiglass? What cam in in there & what are you planning to install?
