?What tractor to pull
TS
12-27-2001 03:49:21
What would be the best choices of tractor models to be competitive in stock condition? What is not generally competitive? I would be most interested in the lighter weight classes. I don't believe I would want an over 5500 pound tractor.
I have never pulled before.
Greg H.
12-28-2001 13:39:33
 Re: ?What tractor to pull in reply to TS, 12-27-2001 03:49:21
If you are talking stock, than you will be pulling against Stock tractors I guess, so here's my thoughts. A good WD45 is never a bad choice. Also a late model JD A with the straight 6 speed tranny. I wonder if a DC case would make that weight. if it would, they are also strong pullers. Those are a few models that are strong in the stock mode. However if you decide to do alot of modifications an oliver 70 rowgrop, or Farmall H would do nicely, and parts are more available aftermarket. Just my thoughts.
Adam
01-03-2002 18:00:52
 Re: Re: ?What tractor to pull in reply to Greg H., 12-28-2001 13:39:33
I have a stock restored f-20. only thing done to the motor was new rings wins every tiome against som hot rod olivers. Dont get a farmall h unless you are gonna put money in it.
cockshuttpuller
12-28-2001 07:41:17
I think a cockshutt 40 would be very competitive in the stock class in 4500 and 5500 what you need to do is get a gas and do some modifications to it like take the sleeves out and put 50 pistons in it and some carb work and electronic igniton and right there you have 60-65 hp . Witch would get you right there and they also got a granny gear in them also that is reallly slow. And in the 4500 and 5500 you should be able to run 2nd gear on a good track. The 2nd gear is about 3 mph. So hope it helps .
former cockshutt puller
12-28-2001 15:35:48
 Re: Re: ?What tractor to pull in reply to cockshuttpuller, 12-28-2001 07:41:17
A D-19 crank in a 40 or 50 block, get your compression up, and get a carburetor to feed it is good for 80 horse. I think what gear you can pull in depends on the sled and track. I used to pull a tractor with the setup I mentioned that wouldn't pull 2nd gear in the 6,000 lb. class on 18.4-38s unless the track was really loose or really hard and slick on top. On the other hand the D-19 motor will bolt up with minor modifications, and with some LP pistons, head work, and a carb. to feed it is good for 95 horsepower.
dick l
12-28-2001 15:45:58
 Re: Re: Re: ?What tractor to pull in reply to former cockshutt puller, 12-28-2001 15:35:48
do not listen to wat cocshutt puller tells u if u want to pull stock say 4500 pound class u have to be under 45 horse power its a horsepower per pound
adam
01-03-2002 18:04:30
 Re: Re: Re: Re: ?What tractor to pull in reply to dick l, 12-28-2001 15:45:58
Dick doesnt konw anything. Most of time all the people at the scaled do is tell you to rev your motor and hold it open. if it sounds like it is about the right rpm you pass unless they have a tahc waiting for you.
Cookie
12-28-2001 13:25:52
I pull a cockshutt40 with the 3 9/16 overbore in the 5500to 9500 pound class.In the 5500 class it is competitive against the higher horse tractors. Whit 18.4*38 tires I can run 3rd on most tracks and 2nd in the 6500.The only thing that has been mod. is the pistons and a good valve job. Got into pulling for under $2500.00. between tractor,tires, and parts.
Shutt30
12-28-2001 10:34:06
Pulling the sleeves out and putting 50 pistons in won't work with out some costly machine work if even then. The 230 Buda has wet sleeves and the 273 Buda has no sleeves. The 230 can be bored too atleast 3-9/16 and the 273 stock bore is 3-3/4. Alot of people are using the 262 Allis combine engine which is 3-9/16 bore and 4-3/8 stroke.
John
12-28-2001 03:39:22
Where are you located? Also what kind of money are you wanting to spend?
