70 carb in a JD G
al
08-05-2004 15:19:14
What's involved in mounting a JD 70 all fuel carb in a G? Should I have the carb worked over first?
I want to mount it to a Jerry's manifold.
Is there any significant power gains?
buickanddeere
08-06-2004 05:38:08
 Re: 70 carb in a JD G in reply to al, 08-05-2004 15:19:14
Still limited by the G sharing one port with two cylinders. Robert's Carb makes a duplex to simplex manifold to do your conversion. Simplest to just put a Robert's 51 carb on a G gasser intake. The only difference between 60/630/630/70/720/730 gasoline and all-fuel carbs is the jetting.
