60+ HP?
TIREDA
12-27-2001 13:09:51
I 've had other posts concerning this topic but here goes. I want to wake my late A (sn 602214)
up. After doing some number crunching, it seems that the stroker combos (cam, carb work, hot ignition, head work, etc.) are making about .16 to
.18 HP/cu. in. A stock model A works out to about
.12HP/cu.in., a 520 John Deere produces .20HP/cu.in. My question is, is it possible to make my A as efficient as a 520? With a .125 overbore @ .20 HP/cu.in. this makes approximately
65 HP. Which is about the number I'm looking for.
I know there are tractors making more power with the DLTX series carb and oem head castings, this leads me to beleive that air flow is not the limiting factor. Can new millenium cam, ignition, and air flow work get me where i want to be? lets hear from some Div I & II pullers with standard stroke A's am I missing something?
reanaldo
12-28-2001 19:22:51
 Re: 60+ HP? in reply to TIREDA, 12-27-2001 13:09:51
Got a 730 LP and I can't keep the traction... got an A and I can't keep the traction... got an MT and it pulls with heart, all the way down in low gear and wins ribbons and pleases the crowd. I painted it with a brush so I think all the gals feel sorry for it, but they love its spirit. My suggestion to you is keep the traction with your A in the 6,000 lb class, and build the engine up until you lose traction again. Have fun.
mike in iowa
12-28-2001 16:26:31
i have a late a with over 75 hsp,stock crank, stock carb,stock ignition,just made it air flow better,bored it alittle bit,did a little cam work also.
12-28-2001 20:24:27
 Re: Re: 60+ HP? in reply to mike in iowa, 12-28-2001 16:26:31
ya, and I have some oceanfront property in kansas city!!!
BushogPapa
12-29-2001 06:49:42
 Re: Re: Re: 60+ HP? in reply to - - - - - - - - - - , 12-28-2001 20:24:27
Well, if an AC-WD-45 can pull nearly 6,000 lbs--on 226 cu. in. ( Nebraska tests )... Then an "A" with 321 cu. in. SHOULD have the potential to do at least as well..! Admittedly the WD had 1,900 lbs added to EACH rear wheel, BUT..... ... I Have a WD-45, and I can assure you it is a FULL 4-14" plow tractor.!! NOW, let us have some ideas...!!!!! I have a JD "60", and have the SAME question....!! Ron.
12-29-2001 14:06:13
 Re: Re: Re: Re: 60+ HP? in reply to BushogPapa, 12-29-2001 06:49:42
are you plowing on a sand dune?
BushogPapa
12-29-2001 06:47:24
Well, if an AC-WD-45 can pull nearly 6,000 lbs--on 226 cu. in. ( Nebraska tests )... Then an "A" with 321 cu. in. SHOULD have the potential to do at least as well..! Admittedly the WD had 1,900 lbs added to EACH rear wheel, BUT..... ... NOW, let us have some ideas...!!!!! I have a JD "60", and have the SAME question....!! Ron.
mike in iowa
12-29-2001 11:09:27
 Re: Re: Re: Re: 60+ HP? in reply to BushogPapa, 12-29-2001 06:47:24
when i pull ,i start at 5500 and go up to 10500 lbs. have beat 4020's and even beat a 4320 one time. can even outpull 560's and 806's
Mike in Mo
12-28-2001 15:54:56
I don't think you'll get that much HP with a stock head, but you probably can with a Heisler head. The reason a 520 gets more HP/CU IN is because it turns more RPM than an A. Airflow is the key to making horsepower, but don't get too wild with the cam. Around 210 deg@ .050 would be a good place to start. Mike
WHAT??????????
12-28-2001 08:15:28
Howdy TRIREDA!!!
Them there are pretty facncy numbers I think 20hp per cubic inch is darn near crazy! Thems numbers is over my head. You must be fixin to spend some serious money! you a millionare? I guess Im happy when my ol G is runnin on both holes and aint leakin oil all over my yard. Why aint you guys leavin them old 2 poppers aloan. leave us ol fellers to pull in the fun pulls.
well that is just my 2 cents worth hope nobody aint mad
Greg H
12-28-2001 13:32:25
 Re: Re: 60+ HP? in reply to WHAT??????????, 12-28-2001 08:15:28
I think you are a decimal point shy of the point {as in .20 hp per cid} However I'd have to agree with you that a good running tractor that you can have fun with is all you need. Later Greg H.
