Heisler
friend
12-28-2001 20:44:11
what is the big deal with the heisler heads? What do they have over a stock JD head? what do they look like? does anyone have pics they could show me the looks?
thanks,
a future puller
BJ
12-29-2001 21:33:24
 Re: heisler in reply to friend, 12-28-2001 20:44:11
I don't remember if you are working on an A or B but one other option you might think about is I have seen a later model A with a 60 head and duplex carb makes for a good running tractor and them parts aren't to hard to find I can't say for sure but the same swap might be possible for a later model B
luke Rhonemus
12-29-2001 13:50:12
A heisler head swirls the fuel mixture and looks basically like a factory JD head. It has more ports to allow the swirl process. May have H stamped in with the part number can't remember for sure though. Have a 41 A I am putting together with a heisler head and manifold and powerblock. Drop me a note if you have any questions, email should be correct. Luke
friend
12-30-2001 16:21:58
 Re: Re: heisler in reply to luke Rhonemus, 12-29-2001 13:50:12
so it's like the swirl head, but with bigger ports? what about the valve thinds I hear on this board about? Why is that a factor? It has bigger diameter or something?
AC
12-29-2001 07:20:48
If you were a future puller you'd pull an AC.
I stick with the johnny poppers!!
12-29-2001 14:03:10
 Re: Re: heisler in reply to AC, 12-29-2001 07:20:48
