Eletronic ing.
missery
12-30-2001 15:39:50
i have a stock tractor that has this system in it. i was wondering if this would change the horse power of my tractor. it was dynoed at 46 hp before i put it in.the system came with it's own 12 volt coil. just curious. the tractor runs a lot better.thanks .
Jack
12-31-2001 07:30:17
 Re: eletronic ing. in reply to missery, 12-30-2001 15:39:50
A friend of mine had his G tuned with points and tried his G with the points in it and left the dyno hooked up and tried it after the electronic ignition installation and the reading was exactly the same,BUT!He was able to readjust his carb and timeing and retrieve about 6 more HP.If you have good plug wires than you can open the gap a little on the plugs and have a little more spark in the cylinders.This was just my observation on a Deere and I hope this helps.
