ChadS
08-19-2004 11:34:57
Re: Farmall H puller in reply to Kevin, 08-19-2004 10:48:39
You are gonna have to do some engine work to pull that weight class, and not stall it out all the time, most H "s wont pull 4500 with out stalling out. Now, I am not at all saying that an H cant pull 5500-6500 lbs, with the proper engine work,, would be fun to beat the M,s or what have ya,, at their own weight. I have a 70+ hp H that we pull in div 2-3 style pulling, in low gear,, you cant stall it, not even at 6500, with 15.5X38 tires. wont even lug the engine. If I find it I will post the picture of it at 5500, man, there is weights everywhere on it,, LOL maybe stick with under 5000lb classes till then,, start light, maybe 4000lbs,, and work your way up, on the hitches,, and wheelie bars,, build wheelie bars strong,, dont skimp on those,, the hitch,, you could go with the modified specs,,, but if it is stock,, the stock drawbar assembly will pull fine in a farm, or div 1 class style of pull. give it a good tune up,, plugs, wires, cap, rotor, fresh fuel, that would be a good start for ya,, will keep ya busy for a while,, go get a I&T shop manual for the Farmall letter series,, those books are very good for learning the tear down, and rebuild process of anything you tackle with your H. Hope this helps,, ChadS
