ChadS
08-22-2004 10:13:02
Re: ChadS, I need more h help in reply to Kevin, 08-22-2004 08:32:04
I run 1 stock cube engine, and the other 2 are strokers, What kind of class are you intending on pulling? Someone put a good refernce to HP it takes to pull in different divisions,, aint trying to make this complicated for ya,,, A good div 2-3 engine for an H is 240ci, 3-13/16 bore, or less,,,, with a 5.25 stroke. ya gotta do clearence work,,, you can go as low as 5 inches on stroke with clearencing the rods, and the tips of the lobes of the camshaft,, and not much block grinding,, and, if you sometime decide to go bigger,,, and you built the engine, you will know what it will take to grind it out to clear a bigger crank throw. the 240 ci H I got makes 70+hp, and rough estimate to build it, was around 3000 dollars,,, I have one much bigger than the 240,,, but that one is out in left field between the 2 in comparison. More later,, ChadS
