77 Questions
Charles
08-31-2004 06:32:32
How much abuse can an Oliver 77 take, tranny, axles? want to pull up to 7,500 lbs and use a 360 cube + engine at high rpms 4500 plus. Where can you get a steel flywheel made and does the 195
engine fit without problems?
770
08-31-2004 14:22:11
 Re: 77 Questions in reply to Charles, 08-31-2004 06:32:32
Seen hubs pop. Make sure that the U- bolts are tight if you are using them.
hartparr2844
08-31-2004 09:25:25
have a 77 with a 350 chevy turning 7-8 grand and have had no tranny problems we pull 2nd 3rd and 4th gear. first time out broke a hub but after welding the ubolts to the axle have had no troubles
