Cylinder volume in a JD G
Geewhiz
09-02-2004 09:29:43
What is or where can I find the volume in a JD "G" cylinder so I can figure compression ratio's.
1950 JD "G" stock equipment.
JDGnut
09-02-2004 11:13:21
 Re: Cylinder volume in a JD G in reply to Geewhiz, 09-02-2004 09:29:43
The volume of the cylinder isn't the problem.. Its getting the volume of the head.. Usually about 300cc in a stock styled G that has not been milled.. the other problem is figuring the volume for the top of the piston if the piston is not flat.. (they can be CC'ed.. but I've never done one in a tractor..) I flip the crankcase up so the cylinders are point up..
Good Luck
JDGnut
Geewhiz
09-02-2004 12:26:39
 Re: Cylinder volume in a JD G in reply to JDGnut, 09-02-2004 11:13:21
What is the volume of the cylinder? Thanks for the 300cc number,for the head? I'll use it in my clculations. I am doing rough math before I disassemble the engine. Do you have these other numbers I can work with?
JDGnut
09-02-2004 14:00:36
 Re: Cylinder volume in a JD G in reply to Geewhiz, 09-02-2004 12:26:39
No I don't have the other numbers... because this will be different with each piston and if the block has ever been decked.. so it is different.. With a taller piston there will be less volume when it is at BDC.. (than a shorter piston.) The number you need is the distance from the top of the block to the top of the piston.. than you will be able to figure the volume for your bore.. Good Luck
JDGnut
fox
09-03-2004 05:30:49
 Re: Cylinder volume in a JD G in reply to JDGnut, 09-02-2004 14:00:36
Do you know the bore and stroke? Is it stoke?
Bore x bore x .7854 x stroke = volume ( in cu in.
To convert to CC take it times 16.39.
G-MAN
09-03-2004 07:42:36
 Re: Cylinder volume in a JD G in reply to fox, 09-03-2004 05:30:49
That formula will give you the displacement in cc"s, but to figure the compression ratio, you must know the volume of empty space above the piston at BDC compared to the volume of empty space above the piston at TDC. The only accurate way to figure that is by "cc"ing" the engine. Cubic centimeters are usually used because they"re handier to work with than fractions of cubic inches, and will provide the same ratio.
