John Deere G starter ?
JD720
09-15-2004 18:51:43
What starter works best for a big G ? I have seen the 4430 type starter used or the gear reduction starters like on the 8000 series tractors.Is there any modification needed to install either one ? Thanks
G-MAN
09-16-2004 07:37:22
 Re: John Deere G starter ? in reply to JD720, 09-15-2004 18:51:43
A friend of mine had a 4430-type starter on his 700+ cube "G". It would start it, but not always the best. I loaned him a gear-drive unit off an 8400 to try and apparently it works like a charm. Probably more money than the Bobcat one that's been mentioned, although you could probably buy a used one from Abilene or something, but the Deere starter also doesn't require any modification, and a starter built to crank a 496-cube 8000 engine is probably going to be a little stouter internally than one built for a Bobcat.
730-LP
09-15-2004 19:22:24
There is a starter shop near here that takes a new replacement starter for a 753 bobcat and changes the drive in them that works great runs around $250.00 I have one on a G with 125 over high compression pistons that starts real good with out opening the petcocks and a friend has one on an A thats stroked to 9 inches starts it real good also.
Bamapuller
09-15-2004 20:11:39
 Re: John Deere G starter ? in reply to 730-LP, 09-15-2004 19:22:24
If you get BobCat starter number 410-12139 all you have to do is bolt it on. No modifications are needed to this number. I have one on 3 different big motor JD's and they do a good job.
colekicker
09-16-2004 08:30:11
 Re: John Deere G starter ? in reply to Bamapuller, 09-15-2004 20:11:39
Hey Bamapuller, I'll try to post a pic of one of your G's from Shelbyvill, TN from August.
colekicker
09-16-2004 08:30:01
Bamapuller
09-16-2004 19:41:25
 Re: John Deere G starter ? in reply to colekicker, 09-16-2004 08:30:01
Thanks, CK. I saw your pictures in the post below. Sounds like you had a real good time.
colekicker
09-16-2004 22:55:17
 Here's a G in reply to Bamapuller, 09-16-2004 19:41:25
third party image
Bamapuller's G
TREE TOPPER
09-16-2004 10:12:05
I put a starter on my 600+ cubic inch G from about a 1997 Power Stroke Diesel. It's a Mitsubishi reduction gear starter. All I had to do was change the starter drive. The bolt pattern was exactly the same as the orginal starter. I am
running two batteries, but the trucks ran two 12
volt bateries also. The tractor has around 9-1 compression, and this set up cranks it over real
well. I don't know the part number for the starter drive, but I probably could find out. My local starter and alternator shop did this for me.
g G
Justin C.
09-16-2004 19:56:14
 Re: John Deere G starter ? in reply to TREE TOPPER, 09-16-2004 10:12:05
I've got the Bobcat starter on one of my G's like Bamapuller was talking about. Mine is 537 cube running about 11:1 compression and with a 925 cranking amp battery it does pretty good. Not the best, but a lot better than the factory starter which left me having to pull my tractor off a lot.
