Doodlebug Puller
George Gibby
01-03-2002 19:47:46
Hey Everyone, I need your ideas and thoughts on building a Doodlebug Tractor for Pulling at a local club here in NH.
For beginners a breif paraphase of the club rules.
Homemade tractor from car or truck components (any combination); no industrial, no greater than one and a half ton axle carrying capacity original, nothing newer than 1942, stock, no weights, no chains.
Center hub to center hub no more than 8 feet.
Fixed draw bar height of 24 inches maximum (pulling clevis will be mounted to this),and attached to main frame. Maximum length from center of axle to hitch point is 4 feet.
No locked rear ends.
Two wheel Drive only.
No manufactured tractor parts.
No Tractor (agricultual or industrial) tires or lug tires.
No rear wheel will be wider than 12 inch tread width measured by ground impression, must be DOT approved.
At least one working brake.
I have no real useful knowledge of vehiciles from these earlier years.
Some of the club members are pulling with flat head V8's.
I would like to take full advantage of the rules and pick the better components like axles with tall gears, transmissions, that will hold up to abuse, and a gas or deisel engine that can be fixed if needed. There may even be a super charged 6,8 cylinder deisel or gas engine that would give good power and not break the bank.
What ideas work for best weight distrubution, like setting back the front axle perhaps?
Are there any books available on puller design?
I'm only in the planning stages but need to have a better idea of what to search for.
If you have some doodlebug stories or hints please
add your 2 cents by sharing your stories.
Best Regards,
G.G.
missery
01-06-2002 06:18:48
 Re: Doodlebug Puller in reply to George Gibby, 01-03-2002 19:47:46
i think i have seen you guys pull down to elliot this past summer. nice show. that is an interesting class to see.
George Gibby
01-07-2002 07:06:55
 Re: Re: Doodlebug Puller in reply to missery, 01-06-2002 06:18:48
I just joined the club this past fall, and they are a very active club.
They are fairly competive within the club and I would like to "hit the ground running" when I finally put a tractor together or what to have in mind if I where to buy some else's project.
I took to heart the first post about the Cadillac power unit, partly because I have a 69 convertible. Cadillac has always had good power, I think a 1938ish v-8 power unit would be a good starting point. Cadillac also had very strong transmission and also had an Automatic available.
At least according to The Complete history of: Cadillac standard of the world, by Maurice D. Hendry. A v-16 would be cool too, but these may be exceptially rare do to lower production and much higher cost at the time.
A stripped down chassies with a rigid mounted axle with some super swampers with a double trans set up, might be a good start.
It might just be the way to go.
Regards,
GG
Big Time
01-03-2002 20:34:58
use a Cadillac driveline. they are bulletproof and will pull a Ford V8 to death. the 331 was available for many years. should be easy enough to find a mill that runs, i never saw one that didnt. put a truck trans in between that and a 1 ton Worm Drive Model T axle, and if the axle dont break your competitors will wish it did.
