H v.s350
Q Thompson
09-20-2004 21:00:56
what has to be done to put 350 sleeves in my H how much machine work what parts and so no?
ChadS
09-22-2004 08:30:26
 Re: H v.s350 in reply to Q Thompson, 09-20-2004 21:00:56
You have to bore the block to accept the 350 sleeves, or take the sleeves out, and bore it to 3-5/8. Use a 350 head gasket when you take out the sleeves, there will be a ring around the top of the bore, where the old sleeve lip was, and there will be nothing there to fill it in, the 350 gasket, is larger bore diameter that the H, and will cover it. ChadS
QThompson
09-22-2004 19:32:29
 Re: H v.s350 in reply to ChadS, 09-22-2004 08:30:26
If you just bore the block to 3 5/8 how thick is the wall? I don't know how to use Email how can I get in touch with you?
ChadS
09-23-2004 07:47:00
 Re: H v.s350 in reply to QThompson, 09-22-2004 19:32:29
The block can take it at 3-5/8. easily. An H block if in good condition, can be bored to 3-13/16 and still run on the original block. Chads
