Gas or diesel
JAP
01-04-2002 17:23:03
We are in the process of building an Oliver 880. We are building it for 6500-8500 and will be used for mostly tug pulling with an ocasinal weight transfer. Should we go with the 354 perkins or a gas out of an Oliver 1850.
missery
01-06-2002 06:13:51
 Re: gas or diesel in reply to JAP, 01-04-2002 17:23:03
if you can go gas powered,do it.that gas engine will out lug a diesel when they are both natruly asprerated.my dads 770 gas has out pulled some big tractors.if you want to see it go to www.maineantquietractorclub.com Dave.
Bob
01-05-2002 15:11:49
I would go with the diesel. You can turbo charge them fairly easly. Plenty of power nat. asp.
art
01-05-2002 18:24:14
 Re: Re: gas or diesel in reply to Bob, 01-05-2002 15:11:49
Gas or diesel depends entirely on naturally aspirated or tubo charged. If you can turbo then the 354 perkins is a tough engine however it is limited by the rotary pump. If you are going to have to run naturally aspirated then the gas engine wins hands down no contest. Without a turbo you can not I stress can not get enough air into the diesel. One other consideration is if you are going to be pulling dead weight the gas engine is much quicker out of the hole and will be more competative. There are a number of very good dead weight pulls in our area and the big disels never fair well. Art
