Chad S. Wheel weights.
Ohio H
09-26-2004 10:41:48
Chad; noticed on the pic. of the 460/H that you use wheel weights. what weights fit the 9 bolt wheel. IH's i have don't. Also anyone use the Case/IH magnum suitcase weights. found some, real reasonable. Thanks, Joe.....
Donnie
09-26-2004 17:04:12
 Re: Chad S. Wheel weights. in reply to Ohio H, 09-26-2004 10:41:48
Stock W-9 wheel weights will work. I use them and didn't have to drill the wheels or the weights. Oliver, Co-op, or F&H wheel weights will work also. Hope this helps.
ChadS
09-26-2004 11:13:23
I welded 3/4 round stock on a small piece of angle iron, and welded it to the rim, the spacing is the IH wheel weight, I had to drill the weights so they slide on and off easier, and use a spring clip to hold them in place. ChadS
