HART PUMKIN FESTISBLE
WILDMAN
09-27-2004 05:06:00
HAD A GOOD TIME ,GOOD PULL. GOT TO SEE THAT PRETTY LA CASE I HEARD ABOUT.
Flogger
09-27-2004 08:08:44
 Re: HART PUMKIN FESTISBLE in reply to WILDMAN, 09-27-2004 05:06:00
That was a pretty good run you made in 5200 super even if you did take the "long way" down the track. Just don't let any of us catch you throwing those 100 lb weights around by yourself again. Give us a holler and we'll be glad to help.
ArtCar
09-27-2004 09:56:19
 Re: HART PUMKIN FESTISBLE in reply to Flogger, 09-27-2004 08:08:44
He gotter done after he hit the NOS switch
WILDMAN
09-28-2004 07:10:33
 Re: HART PUMKIN FESTISBLE in reply to ArtCar, 09-27-2004 09:56:19
NO NOS. JUST PLAIN LUCK.YES THAT LITTLE LEFT HAND TURN CAUGHT ME OFF GUARD , BUT SURE WAS FUN.
LW
09-28-2004 13:59:22
 Re: HART PUMKIN FESTISBLE in reply to WILDMAN, 09-28-2004 07:10:33
You did the right thing if you had stopped at the 50ft line and then started over you may not have had as good a pull, ya'll sure put on a good show pulling at 4100lbs.
WILDMAN
09-29-2004 05:05:23
 Re: HART PUMKIN FESTISBLE in reply to LW, 09-28-2004 13:59:22
THANKS LW . I'M TELLING YOU YOUR NEW TRACTOR IS THE STRONGEST I'VE SEEN INCLUDING NATPA. SURE WOULD BE NICE TO GO TO ONE OF THIER PULLS AND SEE. IT WAS GOOD SEEING CASEPOWER AGAIN JUST WISH HE WOULD HAVE BROUGHT HIS TRCTOR.
CASEPOWER
09-29-2004 08:37:39
 Re: HART PUMKIN FESTISBLE in reply to WILDMAN, 09-29-2004 05:05:23
It's all LW's fault!! I told him front wheel drive wouldn't work, but he just wouldn't listen. It pulls very good in reverse though. Very helpful when backing up to the sled while in the mud. Also the rear crossmount engine idea really didn't help with the weight transfer and I just don't like sitting on the valve cover. Though the vibration is kinda like taking viagra..
LW
09-29-2004 05:40:09
Casepower can now blame me for holding up his tractor, he will blame someone!!!!! !!!!
770 Puller
09-29-2004 07:47:18
 Re: HART PUMKIN FESTISBLE in reply to LW, 09-29-2004 05:40:09
LW If you talk to Casepower, please have him call me about some 101 massey hubs. Pinkpower and I are needing hubs, cast hubs are not holding on the 101, top link is splitting in half. I might need weld-on hubs for this old girl.
ph 828-612-8585
CASEPOWER
09-29-2004 08:31:32
 Re: HART PUMKIN FESTISBLE in reply to 770 Puller, 09-29-2004 07:47:18
Been trying to get a set off. I am about to cut the axle and put them in the press!
770 Puller
09-29-2004 09:07:11
 Re: HART PUMKIN FESTISBLE in reply to CASEPOWER, 09-29-2004 08:31:32
Casepower,
I might need the axels latter on. They will come off with a puller most of the time. I need another F-226 motor or 243! I will be able to come over any time this week.
Thanks, Bryant
770 Puller
09-29-2004 08:48:23
Casepower,
I need the top link, to pull with
call me or leave me your # 828-612-8585
ChadS
09-29-2004 10:46:11
 Re: HART PUMKIN FESTISBLE in reply to 770 Puller, 09-29-2004 08:48:23
770, does your 101 have a chrysler or continental? Brother in law has some parts for 101, and the chryslers, food for thought. He built a stroker in his 101, and got alot better! needs a gear reduction starter though. it has some compression. ChadS
770 Puller
09-29-2004 12:01:57
 Re: HART PUMKIN FESTISBLE in reply to ChadS, 09-29-2004 10:46:11
Chad, Iam running the continental 226,running in 3rd gear. Rust in the tank and hubs have been the biggest problems. I will be making another 101, for my wife, but I have a 243 for it. It will be over 300 when I get it together. Pulled Sat. got 3rd in super, pulled it back half throttle in 2nd, thats not going to win. The 101 massey my wife will be driving will have the original spoke wheels, and wants to paint it pink. She should get into the 3500# class with ease,running 13.8 on the rear, she only weighs 115# s . The nane that she wants on the tractor is Pinkpower. With her driving a pink tractor down the track, and beating out old pullers around here, should make it fun next year. I will post pics when it is put together. I would like to see the tractor in the right color, but it is her project, I am only doing the motor, and carb. I need alot of different parts for both tractors.
I can not find your # Email me your #, or call me
828-612-8585
ChadS
09-30-2004 09:12:02
 Re: HART PUMKIN FESTISBLE in reply to 770 Puller, 09-29-2004 12:01:57
ChadS3@hotmail.com 574-893-7437. Will pass on his number to you. 3rd gear huh? His 101 has the fast tranny, 2nd gear with 15.5.s is about 5.5 mph in his, he has been thinking of changing ring and pinion out, maybe one from a 44. to slow it down a bit. ChadS
