2 cylinder tach??
nimrod
09-27-2004 18:54:32
can someone please tell me where to find a tach that will work in my JD G...only one I can find is for a 4,6,or 8 cylinder. or would these work, and how...thank you for input.
JDGnut
09-28-2004 20:13:51
 Re: 2 cylinder tach?? in reply to nimrod, 09-27-2004 18:54:32
If you are using a Normal Dist.. (not the LP 90 degree dist.) you can get any Tach and set it to the 4 cylinder setting and it will work.. (this is because the Dist fire 2 extra times.. it fires on the exhaust stroke.. and the compression stroke..) the LP dist.. has a gear reduction and it does not fire the same... If you can find a governor driven tach it will work on your G.. it drives off the left hand cover of the governor housing... They are very hard to find.. and you will have to have the shaft, and the left cover off the governor for it to work... They are pricey.. Good Luck
JDGnut
SmartA$$
09-28-2004 16:16:23
They dont make any that register slow enough for a JD. SMARTA$$
BushogPapa
09-27-2004 20:31:01
I have one 630...had no tach..
I put a KW tach in it...it fit perfect, too...!! The drive even hooks up exactly..!!
Since it was Free, I don't mind it saying "KW"...!!
Ron..
